I need the Repair Manual for Maytag Neptune
I need the Repair Manual or service manual for Maytag Neptune Model MAH5500BWQ. We need to replace the inlet value, cold water still running into washer after we pause the washer and unplug the washing machine
Saw your earlier post and it sounds like you figured out your problem on your own. Good.
Right now the Maytag Service Library site is down, so as soon as it comes back up I will link you to one.
Here is your manual. Note that specifics on your model are at the back of it.
http://www.servicematters.com/maytag_library/docs/16010061.pdf
