Brand: Maytag
Model Number: MFI2570FEZ02
Main Symptom: Display dead, no water or ice dispensed
What happens & when: The fridge and freezer are operational, except the display is out and the water and ice dispensers below it stopped working (all at the same time). This happened after the fridge was “complaining” intermittently by chirping a few tones while no one was near it. That chirping happened for a few days, then the display and water/ice died.
I believe that I need a new control board. However, every instructional I’ve read says you need a programming “CODE” to enter after you install the new board.
This code is typically found on the interior of the fridge, on the label with the serial and model number. However, on mine, it just says “CODE” and then there is white space – no four digit code.
Does anyone know how I can get this code? Maytag has been of no help.
Thank you.
