I need help finding a part
Brand: Samsung
Model Number: RF28R7201SG
Main Symptom: Need help to identify a part
What happens & when: NA
Error Code (if any): NA
Parts or tests already tried: NA
Photos / video link: SamsungIceMakerPart - Google Drive
Trying to identify this part. It is a bit melted from when I used a heat gun to melt some ice ('I know, bad idea). This is the plastic piece that protects the Styrofoam surrounding the freezing element in the Ice Master ice maker. It goes around the element and the foam. The auger assembly actually slides into this and the fan mates up with the bottom.
Thanks in advance.
any suggestions on where to find a non blurry parts diagram?
Apparently it is called the ‘Fixer Fan Duct’ da61-08180. It also seems to be out of stock everywhere or unavailable.
Unfortunately, Samsung has discontinued DA61-08180 / DA61-08180A and has not provided a replacement. We recommend checking with Samsung directly or sourcing a used part by model number.
