I messed up!
My dryer would not heat. Found the element was bad and decided to replace it myself. Heats great now but will no longer turn off when clothes are dry. Timed drying still working. I am looking for a photo of how the thermal switches should be wired on the side of the element housing. Diagnostics showing an F-25 error. Any pictures or thoughts? DIY here not a pro!
Note that the polarity on the thermostats does not matter as they are AC devices.
WED9200.pdf (653.3 KB)
