Dishwasher quit the other day mid cycle, water standing on the inside. When I press cancel/drain it only hums like it’s trying to start and than quits…it will try to run again several times before canceling the cycle and never draining the water.
Have emptied the water out and have the interior parts removed down to the bare shaft and the bottom drain hose disconnected and check valve out. Closing the door and pressing cancel/drain button again the unit hums but won’t run…any ideas?
Reassembled and ran a rinse cycle…that went ok. Than tried normal wash cycle, it started fine but about half way through after a drain an fill it wouldn’t started up again. You can hear the motor hum and quit? I switched to cancel/drain and after several attempt it ran finally and drained the unit.
Does sound like a bad motor.
To confirm this you will have to check the windings for resistance and grounding.
Note that this can tell you that the motor is bad but does not tell you that it is good as it may have other problems.
So if it is oK then you have to check it for the correct voltages.
I do not think that I would repair this unit due to the cost and work involved.
[quote=denman;891983]Does sound like a bad motor.
I do not think that I would repair this unit due to the cost and work involved.[/quote]
just to add some additional information. It could also be a failing board, or simply a bad ground as mentioned. Chasing that around can be a real pain. More than likely however the motor and capacitor that starts it can be to blame. See if you can find one used locally, ( used vs new save about 60% of cost of part) and see if you can resurrect the unit. The real pain will be in the replacing of the motor in the housing for those who haven’t done it repetitively, it can be a bit long. 1.5 hours total time. est.
