We recently purchased a used Frigidaire oven and it worked fine. Just the other day, we noticed that the number panel quit working…not all the numbers, just the number 1, the number 4, the number 7 and also the “bake” button. We are thinking that, since the numbers and bake button are all in a row, like this:
1
4
7
BAKE
We’re thinking it must be an issue with that fuse or the plug that goes to that line of numbers because everything else works fine (all the other numbers and the burners themselves work great). Can you give me a clue as to if this is something we can fix ourselves? Thanks for any info. you can give me…it’s much appreciated.
I cannot find any info on the given model number.
Please check it.
If the unit uses a keypad that is hooked to a control board you may want to try the following:
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Thanks…we’ll try that.
