How to test for a faulty Pump Drain ASM
I have a GE Profiler that is not Draining. I have completed taking all the parts apart and cleaned and inspected them all.
I did not find anything that would be jaming the Pump and or from working
I have put the unit in diag mode and tested auxilary pump 2L and the pump does not make a sound. of course i do not know if this is the drain pump test
Is their a way i could test that the pump is bad before i go buy one?
Thank you
Replacement parts for General Electric PDW7900N00WW Dishwasher | AppliancePartsPros.com
Check that the drain pump is getting 120 volts when it should.
If yes and it is not on/pumping, then it is toast.
Could also remove it from the unit, hook it up to a line cord and try it.
