Brand:Frigidair
Model Number:fffu20f2vw
Main Symptom:not cooling
Which fan are you trying to test. The condenser fan or the evaporator fan
Condenser fan is the one I need to
test
FFFU20F2VW — Enter Service Mode & Test Condenser Fan
- Open freezer door.
- Locate the magnetic door switch at the bottom front, near the green Power-On light.
- Pass/tap a magnet over the switch 4 times within 2 seconds.
- On the 4th pass, hold the magnet on the switch.
- Keep holding until you hear a long beep and the interior light comes ON.
- Remove magnet. The light turns OFF and Service Mode is active.
- Test 1 starts automatically: Compressor + condenser fan should run.
- If the compressor runs but condenser fan does not, check:
- Fan blade spins freely / no obstruction
- Wiring and connector
- Voltage at condenser-fan connector
- If correct voltage is present but fan doesn’t run → replace condenser fan motor
To advance to the next test, swipe the magnet over the switch 2 times.
Wow, great information. Where can i get a complete list of self diagnostic that you got
this from? Thanks very much
FFFH20F3WW0 a14353601.pdf (484.6 KB)
