I need to get into the inside of my Maytag Neptune 300AYW to fix a squeaking noise, but I don’t even know where to start. I don’t see any screws on the machine or a starting point at all.
So basically I need to know where to start, and if possible a step-by-step instruction of what to do.
Remove the door, remove the screws on the other side from door, Pull front panel away at top, and remove, remove screws and metal hooks and lift top, remove front drum support, release belt (pay close att. here) remove drum. I would replace rollers and the belt idler pulley!!
