how to reset a frigidaire washer
I just replaced the door switch due to an E41 error. How do I reset the machine to clear the error?
Thanks,
Paul
It should clear itself if you unplug the machine for a few minutes, but take a look at this service manual and see if it helps. It may be you did not fix your problem, so use the troubleshooting techniques to check it out.
http://frigidaireservicetips.com/pdfs/490_3cuftHorizontalAxisWasherSM.pdf
