How to Replace top agitator?
The bottom agitator still moves during wash, but the top agitator no longer moves. I think I can use the Agitator repair kit for my Whirpool washer, but
I have no clue how to disassemble the top of the agitator.
Can someone lead me to a reference source?
Thanks.
I beleive you remorve the top cap by unscrwing or pulling off. then you need to remove the softner cup by pulling up. You will see a bolt holding the 2 parts together. It may be that the dawgs are bad and need replaced.
[QUOTE=jdman;1430]I beleive you remorve the top cap by unscrwing or pulling off. then you need to remove the softner cup by pulling up. You will see a bolt holding the 2 parts together. It may be that the dawgs are bad and need replaced.[/QUOTE]
Thanks, I’ll give it a try!
