How to replace timer control
How do you replace the timer on the above referenced model dishwasher? Our timer knob is very difficult to turn so I assume it needs to be replaced.
Thanks.
Remove the inner door panel. Remove the control panel cover. Pull the knob out. Remove three screws holding the timer.
Assemble in the reverse order.
To find the right part for the timer I need the serial number of the dishwasher.
  • Here are the break down diagrams for the Jenn Air dishwasher Model DW711B
Gene
Thanks for the reply. The serial number is 16618214SZ.
Jim
Gene
Jim
The part number for the timer is AP204723
as long as you turn the circuit breaker off, there really isnt too much to replacing the timer… the door comes off ( door panel ) and the timer control panel comes off and the timer gets unscrewed and wires / harness comes off…
