How to replace the broken ignitor on Jenn-Aire gas cooktop
Two of ignitors on Jenn-air 5 burner gas cooktop are broken. Do I need to unscrew all the screws on all 5 burners and take the top off to get to the ignitor? The screws on burners are too tight. What are the ways to unscrew them? Will heat up help? thanks a lot for your help,
Bei
[QUOTE=bei;56888]Two of ignitors on Jenn-air 5 burner gas cooktop are broken. Do I need to unscrew all the screws on all 5 burners and take the top off to get to the ignitor? The screws on burners are too tight. What are the ways to unscrew them? Will heat up help? thanks a lot for your help,
Bei[/QUOTE]
I see the question but where is the answer?
Bei[/QUOTE]
I have the same problem, but cannot locate any replies. Did you find the right tool? Looking at the nut with the 2 notches, it appears as they way to acess the ignitor clip .
Folks,
In order to replace the igniter on this particular stove you have to remove just the burner with bad igniter, but the only way to remove such screws is to drill them out. You can try to use WD-40, but the rate of success is very low.
I’ve been able to replace a few by removing the torx screws that hold the burners to the stovetop, but the latest attempt has resulted in a stripped screw and I need to drill it out. Spent about an hour drilling with little progress arg. Wish there was a better way.
[FONT=Times New Roman][SIZE=3][COLOR=#000000]The ignitors on my cooktop ignite the flame, but they do not stop sparking. I have replaced a few of them over the years due to this problem. Most recently, I replaced the ignitor on the center (big) burner and the same problem continues - still sparking after flame is lit. Attempted to remove screws on second burner. One screw broke, the other stripped. I need good advice on how to get these small screws. I see talk of drilling… Then what? Also, is the continuing to spark after the flame is lit truly a problem with the ignitor, or is this caused by something else?[/COLOR][/SIZE][/FONT]
If you are having a problem with the ignitor keeping sparking after ignition, I would suspect the ignitor switch on the valve rather than the ignitor itself.
