How to replace retainer ring on clutch
[FONT=Fixedsys][SIZE=3]I’m having a heckuva time replacing the retainer ring on the clutch assembly. Does anyone have any hints???:confused: [/SIZE][/FONT]
I you are talking about the steel wire c ring, you just stick the bent end in the clutch hole, then using a screwdriver, press it in the rest of the way.
:o Thanks, Richappy. It helps to know what you’re doing. I was trying to wrap the ring outside of the four studs.
