I need to replace door switch part AP3777516 as it burnt out on my whirlpool compact dryer. Can anyone instruct me as to how that part comes off so I can replace it? Also the slider on the wire that slides on top prong is also blackened. Is there a replacement part for that or does anyone know how I can fix it? Any suggestions would be greatly appreciated. Thank you so much for your time and assistance.
It looks, from the rawing, like the top slides off after removing the screws in he back. This will expose the front panel. You may need to move a couple components to reach the door switch, but you cn probably get it out and replace it without removing the front panel. [COLOR=“Red”]Make sure you unplug the dryer before attempting this.[/COLOR]
Thank you for your response Magician59…I already have the top off the dryer and can see and reach the door switch but I can not see how to get the door switch off. That is the part I need the help with. And also need to know what to do about the slider at the end of the wire being burnt up as well. Any suggestions?![]()
If there are no screws that attach it to the front, it probably clips or snaps in place. The terminal can be cleaned with a light sanding. If it’s too badly charred, you will have to cut it off and replace it. These terminals can be found in Radio Shack, Fry’s Electronics, or any place that sells electical components.
What a blessing you are to me today…thank you soooooo much…the replacement door switch will be arriving in about a week and I can not wait to try to fix this. your info is invaluable. Thank you!![]()
