Can you please give me step by step instructions on how to replace the oven door hinges for the above model/brand. I received my order from you, but no instructions enclosed. If you kindley can reply asap it would be greatly appreciated. Also should mention that oven is a wall oven in a built in cabinet. Does the gas or electric supplies have to be turned off too!
Thanks for you help!![]()
You do not have to do anything with the gas and/or electric supplies. Remove the door from the oven and put it aside. Each hinge secured with the two screws. Remove these screws and pull out the hinge. Insert the new hinge into the slot and secure it with the new screws included in the kit.
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 54F-5TKXW | AppliancePartsPros.com
how do i get to hinges, does a side or bak panel have to be removed. When removing the door, only part of the hinges are visible, no screws or springs.
There should be two screws on each side of the front panel, above and under the hinge. Then you have to pull the hinge out of the slot.
Gene or other tech
I took off the 2 screws you said, hinge is lose but can’t remove it since it wouldn’t come through the hinge slot, too big(spring and remaining part of hinge. Can’t see remaining part of hinge or spring, only the part where the door slides onto,are you sure you don’t have to remove some other part, side panel,frame etc to see and access remaining part of hinge. If so can you please give detailed step by step instructions. Remember it is a wall oven and in a built in cabinet, not sure if this has impact on the situation.
I have not worked with this particular model, but I did not have such problems with all ovens I worked with. If the hinge does not come out through the slot then the only way to replace them is to remove the oven from the cabinet and remove the side panels.
