how easy is it to get to fan condenser motor for whirlpool ed25dw? its not blowing ‘frosty cold air’..but, i know /.hear compressor kicking on
The condenser fan motor is located in back of the refrigerator next to the compressor. You would need to pull the refrigerator out from the wall so you can get behind the refrigerator. Then you will see the access panel on the back near the bottom of the refrigerator. Remove the access panel and you will see the condenser fan motor.
Should be a easy DIY job to replace.
