Brand:GE
Model Number:PYE22KYNGFS
Main Symptom:indoor coil leaking
What happens & when:z
Brand:GE
If you remove the lower shelf on the door there should be a screw behind it to remove the cover. Once removed you would have access to the tank to replace it.
Also I forgot to ask. Does the water have to be turned off. Thank you.
Yes, turn the water off when doing this.
