How to Replace a Lid Switch
Hi my name is Thomas. Please if you would be so kind inform me in detail with pictures how to replace the Lid Switch for Kenmore Model Number 110.23902200 Top Load Washer 90 Series…Produced by Whirlpool. I hope that I can get to this part WITHOUT removing the entire washing machine cover from the wash bin…In other words I hope that this is doable by entry through the removed console and that I can avoid taking the entire
outside washing machine metal shell off. Thank you so very much!!! You can write me direct if you like which I would prefer. My e-mail is louiemarx@aol.com Thanks Again and Happy Holidays!!!
Tom
You have to remove the case of the washer. Once you got it off the switch is on the bottom of the case. There are pictures and videos on this page Whirlpool Washer Disassembly Guide
Thank You so much when the part arrives I will get started. Is it difficult to get the case back on correctly? Any potential difficulties I should be aware of as I have never done such a job before. I never disasembled a washer and naturally do not want it to vibrate upon reassembling. Thanks again, Tom.
[FONT=Times New Roman][SIZE=3][COLOR=#000000]No it goes back the same all you have to do is make sure the case hooks on the frame in the front. Then it should hinge back up in place. [/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman] [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Happy holidays! [/COLOR][/SIZE][/FONT]
