how to replace thedryer drum felt seal. how do you take off the front pandel
Dryer,
First thing, turn the power off to the dryer, or unplug the power cord. Move the dryer out a few inches, and use a flatblade tool(putty knife) to release the dryer top from the cabinet( there are two spring clips in the seam between the top and front panel, use the tool to press in on the clip and pull up on the dryer top at the same time).Raiseethe top and lean it against the wall, or use a prop rod to hoold it up. On the inside of the front panel, you will find a 1/4 in. hex head screw one on each side a few inches down from the top, remove the screws. lean the front panel away from the cabinet, and disconnect and label the door switch wires, Lift up and out on thee front panel and set it aside once it clears the lower mounting tabs. You’ll need to remove the four(4) screws securing the front tumbler support to the cabinet, and remove the support. You now have access to the belt , drum, and rear support once you remove the belt and drum.
Don’t forget to order the hi temp adhesive
and be very careful with it.
Good Luck,
