I need help, I need to replace the belt in my Amana Washer. HELP!!!
Take off the front panel by taking out the two screws at the bottom that hold it on.
You can now remove the motor, and you will have to then remove the pump from the motor to thread the belt around it and the idler. Put the motor back on and work the belt on to the big pulley.
Is there any place I can see the instructions from the repair manual on how to replace the belt?? It would help alot.
This repair manual does not list your model explicitly but it probably covers it.
http://www.servicematters.com/maytag_library/docs/RS3100005R3.pdf
Thank you so much… I will review it to see if it is close enough!! Thank you!
