how to repair broken water hose?
I have a kenmore elite refrigerator that was moved from my old place to the new house. During the move we had to take the doors off so it would fit through the front door. At the new place I replaced the hose kit in the back of the fridge and ran the water a bit to clean out the lines. The water started to dispense at the bottom of the fridge. When i took the grill of the bottom i realized that the hose that goes from the bottom of the door to the water dispenser was ripped. (that is when i realized i was suppose to disconnect the hose at the coupling under the fridge) my question is there a way to replace that hose. I tried to take the water dispenser out of the door to run a new hose to the bottom but the dispenser housing is extremely glued in with foam insulation. Any suggestions would be extremely helpful and appreciated
forgot to add. i can not thread the new hose by taping it to the old hose because the hose had ripped inside the door by the bottom hinge
