The washing machine is leaking from under the tub between the transmission and the tub but I cant seam to figure out how to remove the tub.
I have the agatitor (sp) out the bolts at the bottom of the inside tub out, the top of the tub off but i still have the outter tub and the inner tub that are still attached.
Can I get to the seals just by removing the inner tub and leave the outter tub still attached w/o having to remove the nuts holding that in place? If so how do i remove the inner tub?
I really need to get this machine working as we have been w/o a washing machine for a week now. I have done as much research as possible on the internet for this model and I dont have a manual for this model.
Attached you will find a picture of the inside of the tub and the bottom of the tub where the leak is coming from. If you need addtional pictures please let me know and I will try to get a better picture using my dig. cam.
This single mother of 5 thanks you in advance.
