How to remove range top
I think I need to replace one of my igniter switches. How do I remove the range top of this Kenmore Elite drop in gas/electric range?
That top will require that you first remove the burner grates and drip pans. Once the burners are removed, you will see two screws under the burners, remove those and the pans will come out. Then,. I believe there are tension clips under the front edge of the top that, when released, will allow the top to hinge up. The pans you need to remove are pictured at the link below.
Frigidaire 318168124 Pan-Burner Large Bl - AppliancePartsPros.com
