There is a large bezel with no obvious points to put pressure for to release. I have removed the screws under the spill tray and have the little spill tray trim piece off
Parts for Electrolux E23CS75DSS8: Ice & Water Dispenser Parts - AppliancePartsPros.com
after that I am stumped and do not want to bend or scratch the metal.
I am looking to replace the water actuator which has broken
Thanks,
John
Looks like there are two screws up from the bottom? Hard to tell from the diagram. Click your model number link and look at the dispenser diagram. The entire face piece comes off by itself. Looks like there are two screws up thru the lower lip of the opening and a bunch of plastic tabs as well I’m sure.
How can I detect the clips or where to push to remove them?
I’ve always just pulled, tugged and pried lightly to see where the sticking parts are. I have terrible luck with bezels and trim pieces though. If anybody else has better experience with them, please chime in and help out.
Well your feedback was the best I could find and I was careful from your advice. So the bezel has tabs that are in slots in the door. After some time the metal was tight. I used a chisel on the inside edge to look in and saw the tabs. Then I took a piece of card board to protect door and then a piece of wood up at the bottom of the bezel and I tapped it with a hammer. After a few taps it came loose! So your were right after the two top screws and the three bottom screws it needed to go up a quarter inch. After that it all worked. We were careful not to pull fast or hard on the ribbon cable. Thanks for replying it really helped!
There is a video on this page that shows how to get in there. Just in case somebody needs it.
Frigidaire 241688401 Ice Door Bracket - AppliancePartsPros.com
Double posted because of site lag.
