How to remove defective wig wag
the spin solenoid quit working. I want to replace the entire wigwag (because it is old). I unscrewed and removed the hold-in pin then tried to remove the assembly. It would not move, even when I pried lightly. I do not want to break anything. Is there anything other than the pin which holds it in place? Is there a secret to it’s removal? :confused:
Thank you in advance for your help.
Remove the bolt and use a flatblade screw driver on its side, in close to the shaft and pry it off!!! You CAN’T hurt anything!!!:smiley:
