The bottom right burner that we use most is not igniting. The igniter is arcing at the base of the ceramic and not at the metal electrode on top. I want to remove the surface burner, but the two screw heads are rusted away.
How do I remove the burner/igniter? I have attached a small piece of wire to create a spark i that little valley area, but that is not working very well. It takes a long time to ignite. Attached is photo of burner.
