How to put in the hinge to the door.
We received the hinge to the lid but can’t figure out how to get the curly end into the hole. Can you explain how to put this part in? The part no. is AP2974008. Thank you.
Hi Noreen
Well, we do this all the time, but explaining how may be a little bit difficult.
Put the curved end through the hole in the lid and then through the hole in the cabinet and twist it until the holes on the part inside the lid line up correctly. You will get it with a little patience. Note, a plastic tip goes on the end that goes into the cabinet, but if you do not have it I do not think it is essential.
Good luck
