Hello, Can you please tell me where the screws are to enable me to lift the top of the stove so I can replace two burners. Thanks.
The screws are on the burners, themselves, under the diffuser caps (see parts #9 in the diagram). You will also need to gently disconnect each spark electrode, before lifting the top.
Main top replacement parts for AMANA ARG7302WW RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
