How to open dryer
I need to replace the dryer door switch assembly. I can’t figure out how to open the dryer. It seems like it would be pretty easy but I can’t seem to find the magic touch.
Thanks!
Here’s your parts breakdown Model LGR5636JQ1
You will need to remove the lint screen & the screws by the screen. Then use a putty knife between the top & front and raise the top. Remove the two screws near the bottom on the front, pull up slightly on the front and remove the front.
Hope that helps
Nat
how do you detach the switch assembly?
If you haven’t already check your email.
Nat
