I ordered (order # 1122134) and received part AP4100487, also called WPL74011278, to replace my oven light receptacle. The original receptacle in my oven uses a common-looking light bulb. The new one does not and the “bulb” is nothing I’ve ever seen before. Here are my questions:
- Is this really the right replacement part?
- The light cover does not seem to be removeable. Should it be? If so, how is it removed? If not, when the “bulb” burns out will I have to replace the whole part again? (The cover on the original screws off to get to the bulb.)
- If this really is the correct replacement part how do I go about getting the old one out and the new one in? (The part did not come with any instructions.)
Thank you!
