How do I safely install a new Baking heating element? It’s a wall mounted oven, so I can’t unplug it. Can I do this myself or do I need an electrician?
Hi Paulette,
Turn off the oven circuit breaker in the breaker box (usually next to the electrical meter).
If it’s not marked properly - turn of the main circuit breaker (make sure all PC’s are off prior to turn the main breaker off).
Remove the screws held the old heating element. Remove the two wires from the heating element, connect them to the new heating element and screw it back in place.
