How to install a new fan/light toggle switch (would like a wiring diagram)
My mother-in-law is having a problem with her fan/light switch operating properly. Somebody else disconnected the old one and purchaced the wrong switch(w/ no off position) I have received the correct switch now but am not sure witch wire color is supposed to be connected to the terminals.I have recognized the Hot & neutral wires but not sure where they connect to the switch terminals. A wiring diagram would definitely be helpful. Thanks.
Here is a service manual, has a wiring diagram and a physical wiring diagram for your unit.
http://www.servicematters.com/maytag_library/docs/16000446(ER001-00).pdf
