I need help getting to heating element I have taken off all the screws on back but it appears to be welded on. The back doesn’t just come off like most dryers.
There is no rear access on your dryer. Remove the front toe panel for access to the heating element.
Eric
Thank you very much for quick response. I kept thinking I had to be missing something because first video I watched showed rear access. I kept looking and scratching my head because I could see weld marks without taking screws out. Have located lower door. I ordered heating element according to that video but will now check some other things before I put it on so that I can return it if not needed. Thanks qgain
