how to get into kenmore washer to repair parts
I can not find out how to get into this washer to even check parts. Do I pry the top open, do something on the back or turn the silly thing upside down. I have a problem where the water does not stop filling even when washer is turned off. I have to turn the water off at the faucets. I was told it could be the water inlet valve or the pressure switch but it doesn’t do me any good if I cant get into it. Most people seem to know how to get into thier washers, but not me. Any help? Sarah
ok looking at console there are end caps one on each end that pull off the console,snap these off and it reveals two screws one on each end phillips head screws,remove screws,then pull console slightly forward and tilt back to get to pressure switch. first thing to check is clear plastic hose that connects to switch if its not connected you found the problem hope this helps
