how to get front panel back on
I’m stumped. I’m having difficulty getting the front cabinet panel back on. I am pretty sure I have the clips inserted in the two slots the way they were. What is the technique for this? I labored for hours with it last Sunday with no success. There are two screws towards the bottom of the door that hold it on once it is snapped into place properly.
If you have the clips on properly, then hold the panel at about a 45 degree angle and hook the clips onto the top panel. Then let the front panel swing onto the bottom clips where you screw it in.
Good luck. If you have the clips on properly this should work!
