How to do continuity check on AP3782822
Brand: bosch
Model Number:SRV53C13UC/46
Main Symptom: won’t start
On/Off button
  • Turns on the setting buttons
  • On/Off button light does not come on
  • Delay start does not come o
Delay/Start Button
  • does not come on
Settings Buttons
  • When on/off button is on, these buttons work
Door
  • When I close the door while on/off switch is on (light is not on but setting lights are on), washer does not come on
Turned breaker off for 15 minutes
The reason for the above post is, once I receive a new switch and install it, I cannot return it if it does not fix the problem. I’d like to do a continuity check on the old switch before I order the new switch.
With the dishwasher unplugged, disconnect at least one wire from the AP3782822 (Bosch 00424410) On/Off switch to isolate it before testing.
Set your multimeter to continuity or the lowest Ohms (Ω) setting, then test these terminal pairs:
  • Pins 1 & 2: Main switch contacts. They should change from OL (open) to 0–1 Ω (closed) when the button is pressed.
  • Pins 3 & 4: Second set of switch contacts. These should also change state when the button is pressed.
  • Pins 5 & 6: Reset/control contacts. On some versions, these only close momentarily as the button is operated, so they may not behave like a standard latching switch.
If any pair that should change state always reads OL or always shows continuity, the switch has failed and should be replaced.
If the terminal numbers aren’t visible, upload a clear photo of the back of the switch. Bosch usually molds the pin numbers into the plastic next to each terminal, and I can point out exactly which terminals to test.
Thank you for the instructions. We removed and tested the switch and it has failed per your directions. The switch was labeled 1, 1B, 2, 2B, 3, 3B. Which corrisponds to your 1, 2-3, 4-5, 6 above. 1&1B showed no continuity; 2&2B showed continuity; 3 and 3B showed continuity. I have ordered a new switch.
Thank you for your quick reply and clear instructions. Also thank you for the clear diagrams in the product pages. I was able to compare my switch to the switch I ordered. The new switch shows compatibility with model SRV53C13UC/01. I have model SRV53C13UC/46.
Thank you for letting me know, glad to help
Well, that didn’t work. I received the on/off switch today. I did the same continuity test on both old and new switches and they respond exactly the same. The dishwasher still does not come on. Same symptoms. When I turn it on:
- The on/offswitch does not light up.
- The setting switches all light up and I can change between settings.  All setting (Power Scrub, Normal, etc) show 43 minutes.  The Quick Wash shows 24 minutes.
- The Delay/Start switch does not have a red light on
- The Delay/Start switch, when pressed and held, does not change the time to 1Hr or 2Hr, et. for the delay time.
- The dishwasher does not come on when I close the door.
- When I close the door, the latch does click, however, I do not know how to test that switch.
What is next for testing and determining what is wrong?
I really like this dishwasher and would like to get it repaired.
Check the Door Latch
Even if the door seems to latch normally, the control must see the door switch close before it will start.
With power disconnected:
  1. Remove the inner door panel.
  2. Locate the door latch assembly.
  3. Disconnect the latch wiring harness.
  4. Using a multimeter on continuity (Ω), test the latch switches.
  • Door open: switches should be open (OL)
  • Door latched: switches should read 0–1 Ω
If either switch does not change state, replace the door latch assembly.
Step 3: Test the Start Button
Since the Start/Delay light never comes on, verify the Start button is actually working.
With the ribbon cable disconnected from the control board:
  • Press the Start button while checking continuity across its corresponding contacts.
The button should change from open to 0 Ω when pressed.
If it never changes, the control panel/user interface has failed.
Step 4: Inspect the Ribbon Cable
Remove the ribbon cable from the electronic control.
Look for:
  • Corrosion
  • Burn marks
  • Bent pins
  • Moisture damage
Reseat the ribbon cable securely and test again.
Step 5: Inspect the Main Control Board
Remove the control board cover and inspect for:
  • Burned components
  • Darkened solder joints
  • Water damage
  • Loose connectors
If everything looks normal, continue with electrical testing.
Step 6: Verify Incoming Voltage
:warning: Live Power Warning
Extreme care should always be taken when testing with live voltage. Electric shock can cause serious injury or death. If you are uncomfortable working around live voltage, do not perform these tests.
If you’d like to know more about how to use a multimeter, we’ve put together a comprehensive tutorial that’s linked in the description.
With the dishwasher powered on:
  • Verify approximately 120 VAC is reaching the control board input.
If 120 VAC is missing, troubleshoot the house wiring, junction box, or power cord.
If 120 VAC is present, the control is receiving proper power.
Most Likely Causes (in order)
  1. Failed door latch/switch assembly (most common)
  2. Failed user interface/control panel (Start button or LED circuit)
  3. Main electronic control board (less common)
Because the cycle selection buttons still work, the main control is at least partially functioning. The failure of both the On/Off indicator LED and the Start/Delay function, combined with the dishwasher never recognizing the door close to begin a cycle, makes the door latch assembly and the user interface the two components I’d investigate before replacing the main control board.
What are the part numbers for the door latch and the Intreface Board?
If the latch is not working, would the on/off switch at least show ON when the door is open. And it seems I should be able to set the delay start.
With the door switch not showing closed it wouldn’t allow the system to send power
The control board ( Bosch 00499497 Dishwasher Control Module | Genuine OEM Part ) on this model controls the user interface as well
Door latch ( Bosch 00438026 Dishwasher Door Latch Assembly | Genuine OEM Part )
Latch switch ( Bosch 00187205 Dishwasher Switch | Genuine OEM Part )
This is a dishwasher with the buttons on the top. You cannot see any buttons or lights when you close the door. How can I tell if the door switch shows closed or not?
Another hint that may help diagnose, when the dishwasher stopped working, it was in a cycle and running. It showed 6 minutes left when I opened the door but would not restart.
Also, this diswasher does not have a ribbon cable. It has individual cables.
That what you said about opening it during a cycle and it never worked after makes me wonder if there isa logic fault on the board hanging it up
I don’t know if I opened it before it finished or if it stopped on its own.
How do you clear a ‘Logic Fault’
If the hard reset of powering it down for 10 minutes doesn’t reset it then the board is bad
Well, the replaced door latch did not solve the problem. Same symptoms as listed above.
You listed 3 possible problems.
  1. Replace the Door Latch: Failed
  2. Replace the Latch Switch: Failed
  3. I am now looking at replacing the Control Board at over $300 which I cannot return if it does not fix the problem and I have installed it.
So I would like to be really sure that this is what I need. Please confirm that the next step is to replace the Control board, part number “Bosch 00499497 Dishwasher aControl Module; Genuine OEM Part”.
I cannot say with 100% certainty that it’s the board since I’m not there to do the diagnosis. My recommendation at this point is to have a qualified tech check it before you buy the board
I gave up. The two parts suggested by the pros that I purchased did not fix the problem and I could not be refunded because they had been installed. This appears to be a guessing game by the technitions. The third thing they suggested I try was to replace a $350 control board which I also cannot return if it does not fix the problem. I feel this is just a guessing game, starting with the least inexpensive part and working up.
In the end, I was not willing to pay $350 to find that my dishwasher from 2011 is still broken. I believe in Bosch and bought a new one, however, I do not believe in Appliance Parts Pros or their processes. If a part does not fix the problem, at least let me send it back and have it checked that it is in working order. If so, then refund me. They now have two perfectly good parts that they can resell.
Hopefully, this Bosch will last another 15 years at which time, I guess I won’t be loading my own dishwasher and won’t care if it fails.
If your Bosch dishwasher is not starting, here are some steps to troubleshoot and fix the issue:
Dishwasher Has Power but Won’t Start
1. Check Door Closure: Ensure the door is fully latched. An improperly closed door will prevent the dishwasher from starting due to safety mechanisms.
2. Deactivate Child Lock: The control panel may be locked. Refer to your manual for instructions on deactivating the child lock.
3. Inspect Door Latch: A faulty door latch may inhibit operation even if the door seems closed.
4. Power Cycle the Dishwasher: Disconnect the dishwasher from the power supply for at least 5 seconds, then reconnect and attempt to start the cycle again.
Dishwasher Doesn’t Have Power
1. Main Connection: Verify the power cord is securely connected to the dishwasher and the electrical outlet.
2. Check Electrical Outlet: Test the outlet with another device to ensure it’s providing power. If the device doesn’t work, the problem may lie with the outlet or your home’s electrical system.
3. Electrical Panel: Check your home’s electrical panel for tripped circuit breakers or blown fuses that might affect the dishwasher’s operation.
Are you following these steps, but your dishwasher still isn’t starting? Please contact Bosch Support or call us at 1-800-944-2904.
Directly from Bosch literature
