How To Check Refrigerator Parts For Continuity
Checking various refrigerator components for continuity allows you to identify a failed component. For example, you can test your refrigerator defrost heater, defrost timer, defrost thermostat (at proper temperature only), fan motor, compressor relay, door switches, and other refrigerator parts.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
[quote=Admin / APP Team;13447]Checking various refrigerator components for continuity allows you to identify a failed component. For example, you can test your refrigerator defrost heater, defrost timer, defrost thermostat (at proper temperature only), fan motor, compressor relay, door switches, and other refrigerator parts.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter[/quote]
Nice article. However, you do not even mention testing refrigerator parts in the actual article. Maybe you should stick in the intro paragraph to this thread into the actual article so it is a better and more searchable document for the future.
Keep up the good work!
Type: Amana
Model ASD262RHRW
S/N 10271102EC
I dont here the compresor working, so there is no refrigeration at all.
Help please.
kind regards
Benji
Defrost problem
How to check adaptive defrost with voltometr
How to check voltage from adaptive to defrost heater
if 110 v ?
Bohdan,
What is the complete model number of the refrigerator?
Can you post it in a new thread, please?
Maytag MZD2766GES
Adaptive defrost white wire 110V,to red,orange wire to red 110v,yelow wire to red 40v I changed new adaptive defrost but nothing change/defrost still not working/ ,I checked defrost heater resistance and it is 30 oms and thermostad is open when it is worm,and is continue it is frozen
You can find the complete troubleshooting instructions in the Service manual(page 2-15).
Here are the break down diagrams for the Maytag refrigerator Model MZD2766GES
I need help locating the defrost timer on my 6 year old Amana refrigerator, model #DRSE663BW. I am having problems with the freezer coils freezing up, causing the refrigerator’s temperature to drop, becoming to warm. It almost appears as if there is not one. Any help you can give would be appreciated.
robinson35,
There is no defrost timer in your refrigerator. The defrost cycle operated by the Adaptive Defrost Control (#13 on the break down diagram) which is an electronic part.
Remove the rear panel in the freezer and check for continuity the defrost thermostat (#11 on the break down diagram) and the defrost heater (#14 on the break down diagram). The evaporator coil must be cold at time when you check the defrost thermostat.
Replace if any of them is open.
If there is nothing wrong then replace the adaptive defrost control.
Here are the break down diagrams for the Amana refrigerator Model DRSE663BW
Gene,
My Kenmore fridge (Model #363.9504784 and Seial #B02610841) has the same problem- Freezer fine, but fridge side warm. I’ve read all the other messages you posted. I don’t have a manual or diagram showing what and where are the defrost system parts are and how to test them properly. I entered the fridge name and model and I’m not getting anything back. I would appreciate your help and guidance. Thank you.
Rudy
Hi Rudy,
The defrost timer is #257 on the break down diagram.
The defrost thermostat is #240 on the break down diagram.
The defrost heater is #230 on the break down diagram.
  • The part number for the defrost timer is AP2061695
  • The part number for the defrost thermostat is AP2639498
  • The part number for the defrost heater is AP2635762
Nice Write up on how to check the continuity with ohmmeter.
The link to the guide isn’t working for me. Is there a new link?
My GE Refrigerator model PFE29PSDASS the dispenser is not dispensing water. The controls switching from water to ice all working. Not making ice cubes in in. Also the bottom freezer light not coming on when open freezer door. Thers’s no sealing sound on any of the doors when closing. I have changed freezer door switch and water inlet valve -no changes. Checked water flow is good. Getting 30volts at electrical connector to water inlet valve.No change when call for water.
The document link is bad.
Urban clap offers the best home service in dubai area. We offers amazing and reliable service for repairing devices such as computer, mobile, refrigerator repair dubai, washing machine repair dubai with a team of 200 professional technicians.
