I broke the glasstop on my GE range, and purchased a replacement, but was wonderin how to actually replace it
[LEFT][FONT=Arial]Remove power to the unit.[/FONT][/LEFT]
[LEFT][FONT=Arial]Remove the two screws which secure the cooktop to the front frame.[/FONT][/LEFT]
[LEFT][FONT=Arial]Lift the front of the cooktop upward (no more than 45°). [/FONT]
[FONT=Arial]NOTE: lifting the front of the cooktop too high, can break the glass.[/FONT][/LEFT]
[LEFT][FONT=Arial]Unplug the two electrical connector plugs and remove the ground wire from the cooktop (located at the rear of the cooktop).[/FONT][/LEFT]
[LEFT][FONT=Arial]While grasping both sides of the cooktop, lift the front of the cooktop upward approximately 30 to 40°[/FONT][/LEFT]
[LEFT][FONT=Arial]While holding the front of the cooktop upward, lower the rear of the cooktop in order to disengage the cooktop hinges from the hinge pins[/FONT][/LEFT]
[LEFT][FONT=Arial]Once the cooktop hinges are disengaged from the hinge pins, lift the rear of the cooktop upward and over the hinge pins while pulling the cooktop forward to remove[/FONT][/LEFT]
[LEFT][FONT=Arial]Here are the breakdown diagrams and Replacement parts for General Electric JBP66WB1WW Electric range | AppliancePartsPros.com[/FONT][/LEFT]
[LEFT][FONT=Arial]Gene.[/FONT][/LEFT]
