Brand:Kitchen Aid
Model Number: KSSS42MWX00
Main Symptom:Freezes up
What happens & when:Sporadically (weeks apart)
Brand:Kitchen Aid
For your KitchenAid KSSS42MWX00, the defrost system is controlled electronically rather than by a traditional mechanical defrost timer.
The refrigerator uses an adaptive defrost system, meaning it doesn’t necessarily defrost at the same interval every day.
Typically:
These are general operating ranges, not confirmed factory specifications for this exact model.
I’d check these items before replacing the electronic control:
When you say it freezes up, is the freezer evaporator coil completely covered in frost, causing the refrigerator section to get warm, or is food actually freezing inside the refrigerator compartment?
That distinction will help determine whether we’re dealing with a defrost failure or a temperature-control problem.
Thanks for the background. I don’t see any electronics and have just replaced the timer as the most likely culprit.
I have had this refer for 20+ years and freeze ups were originally rare and associated with door seal problems. 8 years ago a pro changed out the timer “just in case”. 3 years ago the same pro swapped out the heater and bimetal, commenting that it was time to buy a new refer ($10k). The current rash of freeze-ups started 6 months or so ago.
Yeah, this refrigerator has a timer for defrost.Here is the tech sheet and parts list!
KitchenAid KSSS42MWX00 Refrigerator Tech Sheet-1113730.pdf (1.1 MB)
Part List - 4361001 - Rev B.pdf (491.9 KB)
instructionsheet-482494-revr.pdf (403.3 KB)
Make sure the timer wire that has the loose lead goes to terminal 2 on the Defrost Timer:
