How many wires going in block terminal- Magic Chef range
ETA: Model# 5898VVV
Hello,
Found your forum while trying to search for info on my stove.
I am needing help and hope that you kind gentlemen and women could help me out.
I bought a used Magic Chef range (oven?, stove?)
drop-in, glasstop but the people I got it from didn’t install or uninstall themselves and didn’t know much about what I found back there.
It does not have a pigtail, so I am trying to install a 3-prong.
The far left screw on the block terminal is broken off and (what I believe is) the ground strap is cut.
My problem is the “rigging” that the installer did and what the wires from his “rigging” goes to, I assume they all came from the far left screw that was broken off at the terminal but I need verification.
Planning on taking the block terminal off my old range & ground strap and put it on this one.
I attached a picture showing what it looks like back there.
There are 3 wires going into this “rigging” the black thing on the left.
Thank you in advance
And another, if this one matters.
