How do you take the front panel off?
Take out the lint screen and you will see two screws. Take them out, then insert a screw driver in the gap between the top and front near the edges and pry up. The top will now come up on its hinges and you can see the two screws that hold the front on. Take them out, disconnect the door switch and lift the front off of the clips that hold it on.
