Hi
We inherited a 15 year old Amana fridge freezer that looks new, we’ve never had this style of fridge freezer before and love it:)
I have just connected it up to the water using a water filter and was wondering how the ice maker bit works, if you hold a glass under the drinks dispenser you get a reasonably cold drink of water [could be colder]. If you hold the glass under the ice maker part you get nothing:confused:
This machine makes both ice cubes and crushed ice, a big stir’er thing rotates in the ice bucket but that’s it, I have tried the switch set on both crushed and ice cubes and nothing.
This machine hasn’t been used for a few months [moving and storage] and I don’t have a user manual, is there something we should be doing to get it to work.
Would appreciate any help/guidance as although old this is the best machine we’ve ever owned.
Kind regards
Brian.
Hi again
Well I’ve read loads of posts here to try and fathom this out for myself and not achieved it:o
I did read on here that I could swap the wires over on the two electric water valves [not sure what they’re called] that allow water into the machine, I unplugged each one and plugged them back onto the opposite valve. When I now pressed the drinks dispenser lever the ice maker filled with water [and overflowed into the ice bucket:o ], when depressing the ice dispensing lever I didn’t get any water out of the drinks dispenser:confused:
Not sure what this tells me only that there could be a fault with the valve that lets water into the ice making part of the freezer? I was hoping to swap the water hoses out of the valve over to do another test but the manufacturers make them a different size so couldn’t do it.
Really appreciate any help as I have to order parts from the States and it won’t be cheap with UK taxes added:mad:
Kind regards
Brian
P.S. could anyone explain how the wire trip switch in the ice maker bit works and what position it’s supposed to be in to make ice;)
