How do I replace relay board on amana oven
I don’t know where the relay board is on the unit, how to open the control panel, or how to replace the relay board-
Please help if you know the answers-
01-Door / Control Panel parts for Amana AOCS3040SS / P1132348NSS - AppliancePartsPros.com
Look at image two and start taking screws off the front panel…make sure you turn breaker off
Humbolt Repair Man-
The only Screws I See are on the under side of the Display/Control Panel, and there are four (4) of them-
There are no screws on the sides (facing), and the control panel is tilted back on top so as to offer a better view from above-
If the four screws on the bottom are what you’re referring to, please advise so-
Thanks,
Ghappe
