How do I replace glass on front of oven door?
While putting the oven door back on the oven, the decorative front glass on the door exploded. I have the replacement glass panel. Are there instructions somewhere that will help me through the process?
This is fairly straightforward. Remove door and locate three screws on side of door. One is at the middle and the other two are at the bottom. Remove these screws and and slide off side cover. Then unscrew screw a that attaches the outer glass. Do this on the other side. Then remove screw on the bottom of door which attaches to glass.
The new outer glass pane slides into three groves at top of door. It may be helpful to loosen the top cover on door (4 screws) to make it easier to slide glass panel into the groves. Then replace the two side screws and bottom screw. Replace side panels and replace door onto hinges.
The whole process should take about 10 minutes.
