How do i replace a belt on an Admiral Dryer
I have a replacement belt, but dont know how to attack the replacement. From the front, back or top. Please help asap if you can. Any help would be greatly appreciated! Thanks
See if the links in here will be of help please…
CLICK HERE
Looks like you replace the belt from the front. Place the drum on the rear rollers with the front panel off and put the belt around the drum where the old belt wear mark is with the grooved side down against the drum.
With both arms under drum, route the belt around the pulley and around the motor pulley, the belt will form an S pattern. There is only ONE way the belt will go on with proper tension.
Thank You- Thank You- Thank You, Clothes Are Now Drying And The Drier Is Quieter Than It Has Ever Been!
