I have ordered new Part ap2920814, but I don’t see easy way to remove old one.
Mmcalca,
I think this will help you perform the repair.
Remove the control panel from the front of the door:
- Open the dishwasher door.
- Remove the four(4) torx head screws at the top of the s/s inner door panel.
- Close the door and pull the top of the console away from the door.
- Disconnect the touchpad ribbon from the control board.
- Disconnect the rinse aid sensor wire harness from the switch.
- Lift the console up to disengage the bottom tabs from the door frame and
set the console aside.
Removing the Articulated Vent Assembly:
- Remove the Console from the door.
- Disconnect the wire connections from the wax motor terminals.
- Open the dishwasher door and insert the end of a screwdriver into the
notch in the vent louvre. Support the vent assembly with one hand and
rotate the louvre approximately 1/8 of a turn counterclockwise. This wi
release the louvre from the vent assembly.
Note: The louvre rests on a seal a seal ring. Retain both the louvre and seal ring. They will be reinstalled on the replacement vent system.
Installing the Articulated Vent Assembly:
- Place the seal ring in the replacement vent assembly.
- Close the dishwasher door and align the plastic post at the top of the vent
assembly with the notch in the door frame. - Move the vent assembly into position so the seal ring makes full contact
with the s/s inner panel. - Open the door and place the vent louvre over the vent assembly. Be sure
the louvre makes full contact with the seal ring. - Rotate the louvre clockwise by hand to engage the vent assembly.
- Insert the end of a screwdriver into the notch in the louvre and rotate the
louvre clockwise approximately 1/8 of a turn to lock it in position. - Reinstall the console.
Good Luck,
