How Do I remove lower srpay arm
How do I remove the lower spray arm and the plastic screen to clean out my dishwasher. GE Modale Number GHDA475M00CS.
The lower spray wash arm can be removed by
gently lifting and rotating it counter clock wise.
The nut hub can be removed by rotating it
counterclockwise.
Caution: Use care to avoid breaking the clip on the
hub when removing the main conduit from hub.
Appreciate the info
Can you buy just the part with the clip? Mine broke despite me being really careful. The entire arm to replace is at least $60, I was hoping to just replace the part with the clip. Is that possible?
Depends what part is broken.
See the below parts breakdown.
Parts for GE GHDA475M00CS Dishwasher - AppliancePartsPros.com
[QUOTE=denman;902535]Depends what part is broken.
Parts for GE GHDA475M00CS Dishwasher - AppliancePartsPros.com[/QUOTE]
It’s the clip that attaches at the bottom, in the pic on the page here:
https://www.amazon.com/GE-WD12X10057-Conduit-for-Dishwasher/dp/B004H3XRRY/ref=sr_1_1?s=hi&ie=UTF8&qid=1477124707&sr=1-1&keywords=WD12X10057
It’s the little clip on the left side down by circular part where the tube goes in there.
