I have a Maytag washer model MAV6275AWQ.
One of the two bolts that holds down the drive motor is broken. I just need to get the front cover off the machine to get at it.
I feel two clips on the bottom edge of the front cover. Don’t see any screws anywhere. Did see screws at on toward the front of the cabinet on the right and left sides at the bottom edge but they don’t seem to be attached to the front cover.
How on earth do I get the front cover off?
Thanks,
Joe
HJoe, if you get a putty knife, and slide it under the top on the right side, about, 3 inches from the end, you will hit a clip, that will release the top on that side. Then do the same on the other side. Once the top is up, lay it back and rest it on the back wall. Then there will be a screw on the left side, and one on the right side, they will be either on the inside of the front , about 6 inches from the top, Or, they will be on the top of the front on the left side and the right side, once you get the top up. Make sure you unplug the washer, when you do this. Tom ApplianceEducator.com
Tom,
Thanks! I did just what you said and it worked perfectly.
Thanks a million! Joe
