My machine won’t complete a wash cycle. It goes down to “1” then stays there. It will complete a Rinse/Hold cycle normally. I have read through other posts and it looks like I need to at least inspect the control module and possibly repair or replace it. How do I access the module? Do I remove the panel on the back of the door or go through the front? Thanks
The model number you posted is incomplete. It suppose to be two more numbers after “/”. Verify and repost it.
[quote=Gene;282474]The model number you posted is incomplete. It suppose to be two more numbers after “/”. Verify and repost it.
Gene.[/quote]
Sorry, the entire model # is SHE44C05UC / 40
You can find some useful information as well as a pictures in one of our previous threads: http://forum.appliancepartspros.com/dishwasher-repair/3586-bosch-dishwasher.html
- The control module AP4434739
Thanks, I will follow the instructions. Is it possible that I damaged the module by running the dishwasher with low temp water? As mentioned, my water was at 105F (not sure why)?
I do not think so.
Keep us posted.
I finally got the nerve (and time) to get to the controller and sure enough, I found a ‘smoked’ trace on the circuit board. I see that people have had limited success re-soldering the connection. I tried but I am not confident in the results as it looked like the relay pin was gone. Have you (or anyone) had any success replacing the realy?? It is a $1 part (+$7 shipping) but worth a try I think at least. Unless persuaded otherwise
Did you replacew the relay? I would rather try that than pay $167 for a new control module
Yes I did replace the relay. I followed some advice on an alternate (better) relay and so far 3 months into it, it is working wonderfully. I ordered 2 replacement relays from Digi-Key and with shipping it came to $5.87 (and that was two relays in case I screwed one up!). It took me about 10mins once I had the board in hand. The only trick is you want to make sure the replacement is snug to the board as it is taller than the original and will not allow the housing to close without riding it.
Go to digikey.com and type in either T7CS5D-06 or digikey p/n PB336-ND and that should bring up a 6VDC-12A relay at $1.90.
As I understand it, the design is bad. The original relay is slightly undersized at 10amps. The replacement is 12amps. Just have to throw in: Not impressed with Bosch (or whoever) not owning up to marginal design.
GOOD LUCK!
[quote=Gene;282548]You can find some useful information as well as a pictures in one of our previous threads: http://forum.appliancepartspros.com/dishwasher-repair/3586-bosch-dishwasher.html
Gene.[/quote]
Re: Bosch she44c05uc/22 I have the door apart and have access to the control panel however I cannot see how to remove the defective CP without damaging the hole in which it sits. I have looked in the text of the dishwasher training manual but it doesnt provide the info I need. I guess I need a picture (s) of the removal. Can you assist?
Thanks.
Go to my post from 09/30/2010. Click on the link and go through the thread. You’ll find everything.
MANY of the Bosch dishwashers have a recall on the Control Module’s that Bosch pays to have repaired. Mine is…repairman is coming next Monday!
The link to check:
I realize that this could be an older thread, but I came across it searching for answers, so others may too. =)
I can easily get the door and panel off my Bosch dishwasher but cannot budge the plastic module housing, nor can I separate the stainless steel outer fascia from the inner piece (assuming that is necessary).
I have full access to the back of the module but can’t get it out to swap for the new one!
Any suggestions?
What is the complete model number of the dishwasher?
Gene, Thanks so much for the response! It is SHU6805UC/U12. It’s a stainless model and I got the door cover and upper panel off no problem.
On the back side of the upper panel that houses the module I can easily see and access the rear of the module and the wires/plugs… however I cannot figure out how to get the darned module out!
Do I need to separate the the stainless outer fascia of that upper panel from the piece holding the module, door handle mechanism, etc.?
If so, how? And does the module comes out the front?
Any guidance will be GREATLY appreciated! All the videos I’ve seen are for other units that don’t look at all like mine.
P.S. just FYI the reason for all this: it freezes at 1 minute and never drains. I bought a new module online and hope to change it myself.
Click on the following link for instructions: http://forum.appliancepartspros.com/dishwasher-repair/3586-bosch-dishwasher.html
BTW, this link has been posted on the previous page of this thread.
Thanks, I saw that. But… I was unable to locate “the four locking tabs” you referred to. I will look again.
